IMO It was detonated without a shadow of a doubt....Why, who knows. It could have been the tune, air leak on the motor or poor fuel.
Little more info, agree or disagree lol. thanks for the replies from all of you by the way.
Ok after me consulting a couple guys and my turbo kit guy consulting MANY experts and reviewing the several logs they had access to it has been determined it is not detonation, but if anything pre ignition. Why is the thing we are trying to narrow down. One VERY respected polaris guru came out and said this very likely could have happened last spring breaking it in, pre turbo. All is a bit of speculation at this point, but these guys have Way more knowledge than i or most others for that matter. Bad fuel??? maybe we now know we were over boosting a bit, so maybe some of that?? fuel delivery issue or excess air entering they system somehow????? ruling some things out, and will be testing for some once sled is back together.
Turbo kit man has been doing everything to try to find a cause and solution, even sending me some stuff to help get it back together.
I was feeling like a complete idiot thinking i wasn't hearing the detonation, but now appears i was not hearing it cause it wasn't there. Deto meter did not go above dangerous levels according to log.
Hopefully this was just one of those things that happens, and when put together it will run great, but definitely will be double checking a few more things and will be keeping a eye on the fuel quality as best as i can
I purposely left out the kit company, so this couldn't turn into a bashing of him, since this, in my opinion, was not a kit issue. Any issue more than anyone adding a turbo to a two stroke anyway LOL.. Some of you have figured out who's kit it was and started ringing him with calls. That actually helped to rule some things out, so thanks for that too. There is a lot of behind the scenes knowledge on these forums.
thanks
I am no expert in this, so if i might have screwed up a explanation or two in this post sorry.
I have an hm turbo kit with vipec and we were running a pump gas kit to begin with.
6lbs of boost and pump gas at that elevation will result in DET
The vipec has the ability to store DET but as far as I know they were unable to make the fault to appear on the dash
You have to set the threshold on the Vipec to store a DET code, if the threshold was set too high then it wouldn't store any DET codes
If you were overboosting and running that low of octane, your problem is pretty simple, DET
Don't bother taking a chance, mix in some AV.
Were you running EBC on this sled??
The injectors in the 800 CFI-2 motor do not like torco. Please don't use it in this motor. This motor is not your turbo yammie.
Please use the proper octane needed for your elevation. Race fuel or Av Gas.
And btw....none of this carnage happened when the motor was stock! Period.
Its funny that when a turbo motor gets porked so many folks are saying the detonation monkey is on your back.
If your piston is burnt off at the crown by the exhaust port it is caused by a lean condition.
If you piston crown or the fist ring land is busted off its detonating, pre ignition is a much more severe condition than detonation
Deto monkey at work
Boyko would know better than I. I realize you do not want to throw the turbo guys under the bus, but please reveal some more info about your setup as there are a lot of things the turbo guys can learn from people on these forums......not speaking from personal experience or anything....My next question is, what injector setup are you running?
Boyko, looking at this pic (my sled last year,) you would say a lean setup? Not DET? Despite the plugs looking similar to yammiguys.
from what i have gathered in the past 48 hours The experts would not call that DET. but a fuel delivery problem (bad fuel being one possibility) for what that is worth LOL.
What injector setup were you running yammi4ever?
Lol. The real question is what is the side effect if a fuel delivery problem......detonation. Oh and the bad fuel.....there is that pesky detination again.
I agree that it could be a fuel delivery problem or an air leak but also remember an injector being programmed to not remain open long enough to provide the proper amount of fuel could also be described as a fuel delivery problem![]()
I run at 0-1500' (hm turbo) on straight 91 at 7-8psi for 4 years now trouble free and all of our customers run the same with same results (push turbo, boondockers, silber kits). It all depends on the tune you are downloading to your ECU. Intercooler is a must to me and we all run them over here(of course they all run our ECU though)
I've seen the same type of piston damage before, even on stock carbureted sleds that were jetted incorrectly. One of them was a few weeks ago. I doubt deto was a issue on this carb sled because the sled ran fine and crisp at 0 Celsius, temp dropped to -26 and the dude had a midrange burn down. piston both looked the same as what was illustrated at the beginning of this thread.
Someone well experienced with the tuning the vipec could look what was logged in the ecu and have a better idea then you are I as to the cause, it might not be related to the tune.
Dan how long have you been tuning turbo 2 strokes for?
Do you know why the difference between pre ignition and detonation is so significant to a tuner?
