what you are looking at is essentially two different conditions....the time you spend the most throttle time on is the wash around the edge of the piston, but it's quite likely that you have a lean spot which is what the overall lighter color is in the center of the piston....so what was the last minute or so of the engine operating conditions before you shut it off? if it was wide open, you have a lean spot there, or maybe it was in the 6500 rpm area, in which case you are probably lean there...getting reliable wash readings in the field with a laydown engine is very difficult and time consuming without a borescope...learning to read spark plugs is much easier to deal with....and what octane fuel are you running?....from a good name brand station, or something else?....head mods to your engine?....all play a part in deciding what it is you're looking at.....back to spark plug readings....if you look at the ground electrode (the upside down "L"), you have the vertical part and the horizontal part that goes over the central core electrode....if the coating (the burned on deposits) are on the horizontal part of the electrode, with the tip burned clean you have a rich condition....as you lean up the mixture, the line between burned deposit and clean electrode will migrate around the corner of the "L" electrode until it is on the vertical part of it....when the deposit line has migrated about 1/2 the way between the corner of the "L" and the very top of the threads of the plug, you're right where you want to be....you need to check various rpms' for about a 1 minute run to check for mixture throughout the rpm range of your engine....the wash on the top of a piston generally reflects the most time at any one condition that the piston sees...only by riding at a specific condition, and immediately checking wash will piston wash be reliable....but plug readings are much faster, and when correlated with egt readings, will make for a dependable tuning aid
