Hey GHF, sorry I missed what everyone is saying is a crack when you emailed me those pics. I would still wipe the piston clean once the top end is off but while you are in there I would definitely do a "fix kit". Mtntek is pricier but they are probably worth it. Spacer / gaskets / taller pistons.
When you need a hand give me a shout, I just did the top end on my 860 and know all some tricks to make it easier / safer (wrist pin clips into the crankcase are a bugger). I can swing by after work if you run into anything that you need a hand on. Also, have Polaris run a hone through the cylinders to put some new fresh scratches in it. I did my own with my own hone but I would actually prefer normally to have the shop do it, their hone technique is usually better.
Sorry I have been so obsessed with finding my own no-start problem I did not even ask how your sled project was doing! When you are done it will be solid as a rock.
