took my cyliners off and found my sled got a little hot and sezed up. and one piston has a hole that is starting to bore in it. what would be causing this?
I assume it's your 04 Rev? Do a search for "detonation" and another one for "carb boots"
That would be my first guess.
dont mean to thread jack, but ive had detonation problems too and am wonder what plugs everyone is running
Pulled my jets out and they are 380's. Is this too lean? What is everyone else running? And i am riding around 6000 and above
yea i got some 420s laying around but that seems pretty big. does the pipe, can and head set up lean it out a lot? and also i am curently porting and polishing my cylinders. what will that do?
are you using the correct spark plugs
that can be a problem on all the 800 motors
standard br9es will cause damage
was there any other signs of it being lean
piston wash on exhaust side of cyclinder and piston
I would have a engine leakdown test done
sounds like you have a seal leak
could be as easy as carb boots but could be crank seals
Did the hole get burned all the way through ?
If so you could have stuff in places you dont want it
