Is it common to see the pistons like this? I have done some piston replacements in the past and have not seen the dark brown/black on the side of the pistons like this.
These pistons are out of 2 different sleds, both with ~3000 miles on them. One piston is from a carb engine and the other is from a DI engine. Is the oil or heat causing this. I do not want to disclose the type of oil I'm using, I do not want to start bashing thread.
How often are you other sledders seeing this?
Is it typical?
Is it something to worry about?
I was told that worn out rings are causing this and not much of a concern.
Any advise would be nice. I will now have 2 new rebuilt engines.
Thanks.
Is it typical?
Thanks.
