I have a 2010 m8 with a cutler turbo. Been thinking of wrapping exhaust pipe with header wrap. I've seen a couple done. Just wondering are there any cons ov this? Is it worth it? Does it keep to much heat in the pipe and cause high ex temps?
That is why you wrap it ids to keep heart in the pipe and keep out of engine compartment. I do all my personal sleds.
And you need a bunch, not just 15ft. I think I used almost 100ft. believe it or not. Someone on here suggested welding a bunch of "nubs" all over the pipe and then the wrap will actually grip the pipe better and not require so many wire ties. I did this and it helped a bunch. With the wrap and silicone spray you'll be into it $70 plus. It holds the heat awesome.
