B Bridger Active member Dec 24, 2010 #1 10 M8 PG Turbo Getting wierd codes thrown at me. Got a 17 so I picked up a new pipe temp sensor...getting same code. tired another sensor off friends sled...same deal. Also getting a #1 then #17... Any ideas??? Thanx
m8magicandmystery Well-known member Lifetime Membership Dec 24, 2010 #2 all i know FOR CERTAIN..is that a loose sparkplug cap will give that code sometimes...so make sure they are pushed down all the way..
m8magicandmystery Well-known member Lifetime Membership Dec 24, 2010 #3 ps...also check your pipe sensor wires downstream of your pipe sensor connection..it may be pinched etc
snakeye New member Lifetime Membership Dec 24, 2010 #4 Code 17 My sled was doing same thing had broken wire on back side of plug real common I check there
B Bridger Active member Dec 25, 2010 #5 Thanx.. will give that a try... Is that code 1 then 17 most likely the pipe sensor too.... I am not aware of a code 1.. thanx
