Pin Weight vs RPM
Grams to RPM
1 Gram will equal 150-200rpms
Lighter = More rpm
Heavier = Less rpm
Clicker numbers kinda work the same, but work the ramp angle.
200rpms for each clicker number.
If you over rev on the lower and under rev on the higher, then:
Lower the clicker number and add pin weight.
Reverse for opposite senario.
If your sled pulls 7700 throughout speed range, then lighten the pin weight only.
