Does anybody know if this is true?
Boone just curious where did you get your black gas cans from?
Bark1000
I just bought the 09 bumper, edge rails and support gussets. Then trimmed the handle part off my old bumper, trimmed it to fit, used a sanding wheel on a grinder to sand off the nub in the middle on back, and put a couple extra bolts on the sides.
Boone
So, did you have clearance issues with the WRP boards and the 09 rail edges? When I did this mod on my king cat I was running cutler no snows and the 09 rail edges would not fit because of clearance.
i am in the middle of doing this to my 07 M8 and im having alot of trouble getting my gussets to fit correctly. Do you HAVE to buy the 09 edge rails so the gussets fit correctly or is there a better way?
Wyo, that's a mount for my jack, I know you Guy's up north aren't use to seeing those things!That chunk of aluminum sticking up looks like a killer, I have seen guys get real tore up from just gas racks, that thing could take half your leg off if the sled got away from you in the wrong way, smooth that baby out or get rid of it.
Has anyone made their own conversion just using aluminum and fishplating the whole rear section? I think this is the route i am going to do, wont look as nice but will definetely be stronger.
Here is my 06, used 09 bumper and gussets. everything else is stock. just a bit of trimming the old bumper/cooler cover. I learned the hard way on my 900's when i did this. I cut it flush on the tunnel. I learned that took away all the strength. On this sled I left 3/4 inch of the running board side. It is crazy how much strength you get just from that rolled edge of aluminum.
So all you did is buy the 09 gussets and rear bumper then, everything else worked fine? My brother wants to do this with his 08 also.
