U
Very happy with the job done on my clutch by the local machine shop. They have a dynamic balancer specifically for clutches and did a great job.
I had to disassemble my clutch myself which for me is fine, and then they balanced each component individually. Fixed sheave, movable sheave, spider, and cover plate. All were balanced and then assembled as a unit to confirm a true balance. Total cost was $117 Canadian which is about 90US including tax.
Individual balancing components for us 900 guys is pretty important considering the use of 11 series, 10 series, MTX and other weights which changes the belt to sheave clearance requiring re-shimming. Along with the use of the 1115 belt, being able to re-shim without re-balancing is definitely the way to go!
You will notice the small "x" marked with a sharpie close to where they did the material removal on the cover plate. This is where I marked the clutch heavy point when I did my own static balance to index this heavy point with the bottom dead center of the crank to offset the .0025" runout I have. This was a temporary band-aid that I did until I found a good shop to do the balancing.
Before this I had considered sending my clutch to Indydan but with the exchange the way it is plus shipping both ways I simply needed to find an alternative here in Saskatchewan or at least relatively close to keep it affordable.
Ive went through almost the entire "to-do" list for this HOG with the exception of the TM bottom end but I am going to keep an eye on my runout until it needs some attention.
So far I have...
Reliability Issues
-Inspected the torque and push arms (replaced the push arm rubber as it was destroyed)
-Built a simple engine mount for the dial indicator and checked crank runout to be .0025" 1/4" in from the end of the crank
-removed front radiator and eliminated the loop going to the coolant bottle
-installed scratchers
-installed a heat shield to the top of the throttle bodies to protect the rubber boots from exhaust pipe heat damage
-installed vent kit for the clutches (Further venting is planned but I will be fabbing these myself after paying what I did for what I got)
-Removed .020" shim from the primary after installing 11 series weights and the 1115 belt to get .015" clearance
Performance wise
-Installed a used SLP Pipe and silencer (Purchased a Calibration ID from SLP $50USD)
-Have both Polaris ALMOND 140-330 and SLP Black/Yellow 120-310 primary springs to try at 4000-7000ft in 2 weeks time
-Purchased a 66-44-46/66-40-46 NON ER and a 70-46-46/72-48-46ER (Thanks Ebay)
-Purchased 3 derlin washers for the secondary
-Purchased a Black/White secondary spring
-regeared to 19-41, see what happens there
-The only issue outstanding at this point is the weights for the primary. I have 11-68, 11-74, 10-74 (2 sets) and don't want to purchase weights at this point unless I can't make one of these sets work. If need be I will make the 11-74s lighter until they work. I am fine with grinding them down.
Definately going to have one day of tinkering on my mountain trip but thanks to members of this forum as well as HCS I have a pretty close starting point in my opinion.
Thanks for all the help so far boys!![Face Icon Small Happy :face-icon-small-hap :face-icon-small-hap](https://www.snowest.com/forum/images/smilies/old/face-icon-small-happy.gif)
![IMG_1320_zps5jgbefoq.jpg](http://i347.photobucket.com/albums/p442/mrtwinder/IMG_1320_zps5jgbefoq.jpg)
![IMG_1319_zpsx6tbh2ma.jpg](http://i347.photobucket.com/albums/p442/mrtwinder/IMG_1319_zpsx6tbh2ma.jpg)
![IMG_1318_zpsbw6d8vrh.jpg](http://i347.photobucket.com/albums/p442/mrtwinder/IMG_1318_zpsbw6d8vrh.jpg)
![IMG_1317_zpsiiqjyuxy.jpg](http://i347.photobucket.com/albums/p442/mrtwinder/IMG_1317_zpsiiqjyuxy.jpg)
So far I have...
Reliability Issues
Performance wise
