E
el king cat 900
New member
i want see it in 36 and 39 please
I went 36". After 3 days hard riding in bc this weekend I'm convinced it was the correct decision. I didn't feel any downside and it was much more nimble.
Is it 36" in the narrow position? (meaning 38" in the wide position?)
Bump to the top to answer this question
When you order these direct are there any other parts required.. or simply unbolt stock and bolt in new? It comes with bushings and you reuse the stock ball??
You have to shorten the shocks to 16 1/8 or 16 1/4 or else they will bind. I also am not sold on them and wished I bought alternative impacts
You sure on this? Zbroz didn't mention...
It is recommended to run the short shocks are you may get upper ball joint binding for the 36" kit.
It is recommended to run shorter shocks are you may get ball joint binding for the 36" kit.
