Well I've been working on this project on and off, mostly off for the last couple of years but decided it was time to finish it. Here's what I've got so far
Bulkhead is from a Mountain max but has been altered to rider forward. Gas tank is 3" forward and the bars are about 7" forward of a stock MM
144x16x2" track ported
Dropped and rolled chaincase with reverse
Custom bars
Phazer 500 motor Aeen pipe from an older Phazer with side exit and 38mm carbs
Custom tunnel
Skid was from an Rx1 turbo we got but came in a box full of parts. I think it is a Kmod rear but I grafted it onto a set of 141 Cat rails and used a Cat front arm with a Yami shock I had lying around so who knows. Has a ton of travel and seems to move quite smoothly
Custom light weight front end I built a while back but never used opn anything
Skis in the pics are not what I'm using I have some Mods that'll be going on there.
Left to do:
Some wiring although it is running now
Hood
Custom flattop high rise seat
Clutch guard
tuning and probably a bunch of other stuff as well
Mount the tach
I'd like to get some nicer front shocks for it
I haven't had it on the scales yet but it is SUPER light. I can lift the back with one hand and the front with 2 hands no problem. I had weighed all the parts as I was going and I figure it's about 300 right now dry. Should haul my 100 lb kid around pretty good I figure.
M5
Custom bars
Custom tunnel
Left to do:
Hood
Clutch guard
Mount the tach
M5
