Was working on the Phazer, and after reassembly I am seeing
Yellow Caution light keeps blinking / Engine Light blinking on Display
Error Codes 14 & 26 alternating back and forth
Code 14: Intake pressure sensor hose problem.
Hose is detached, loose, plugged, pinched, etc on Cylinder #1.
Code 26: Intake pressure sensor hose problem.
Hose is detached, loose, plugged, pinched, etc on Cylinder #2.
Checked the hoses on both ends, they ARE connected and not crimped in any way.
Checked the Oil Tank Harness and it is plugged in.
At first the sled would not run, started and quit.
Now it runs, but the codes are still flashing.
Code 11: Cylinder identification sensor or circuit problem.
Code 12: Crankshaft sensor or circuit problem
Code 13: Intake pressure sensor or circuit problem on Cylinder #1.
Code 25: Intake pressure sensor or circuit problem on Cylinder #2.
Code 14: Intake pressure sensor hose problem. Hose is detached, loose, plugged, pinched, etc on Cylinder #1.
Code 26: Intake pressure sensor hose problem. Hose is detached, loose, plugged, pinched, etc on Cylinder #2.
Code 15: Throttle position sensor or circuit problem.
Code 16: Throttle position sensor is not moving.
Code 21: Coolant temp sensor or circuit problem.
Code 22: Intake temp sensor or circuit problem.
Code 30: Oil pressure sensor or circuit senses low engine oil pressure. ECU turns off main relay and stops engine.
Code 33: Open circuit in the primary circuit of the Cylidner #1 ignition coil.
Code 34: Open circuit in the primary circuit of the Cylinder #2 ignition coil.
Code 42: Speed sensor or circuit problem.
Code 43: ECU unable to monitor system voltage due to an open or short circuit in fuel system circuit.
Code 44: Internal ECU problem with CO setting or adjustment mode.
Code 46: System voltage is too high or too low.
Code 50: ECU internal memory or data problem.
Code 65: Knock sensor or circuit problem.
Code 81: Grip warmer open or short circuit.
Code 83: Thum warmer open or short circuit.
Code 84: TORS system has been activated.
Code 85: Short or open circuit in oil pressure switch.
Code 88: Short or open circuit in reverse indicator switch.
