H
Hammertime
Looking at these two options, I ride trees most of the time will the RG turbo lag be a problem vs the pump gas setup?
I say rg, the option is worth every penny, but I ran pg quite often or 1 gal of av with pg and got closer to 8-9lbs with the oil I run and a stabil type additive called Enzyme.
The kit, clutching and fuel tuning is more important when it comes to response. If you put to much octane in it will effect it but thats easy to know where you should be.
Hammertime, midgrade???? Premium+AV, period, end of discussion. Like was mentioned earlier, DO NOT CHEAP OUT ON FUEL OR YOU WILL REGRET IT!!!!!
These newer Boondocker Kits work well, and privided tuning numbers are really close. You will like the kit. I have run across" a number of M series late model boondocker kits on the hill, with satisfied owners, including myself. Wyo, have you been around any of the newer M series boondocker kits?
