!!! Does perks complete motor balance kit work !!!
Now to cover the issues of the "New" product and services.
I will start with the problems or negative issues that are TRUE.
1. The aluminum rotor in the 2009 thru 2012 (Ski-Doo's) we have recalled because of 4 structual failures. Issue has been resolved with a high temperature high carbon steel material. (reports have been more power smoother, etc.). And yes for all those who haven't received their replacement, they will be sent this week if my machinist gets them produced.
2. Recoil breakage caused by clearance issues,shim thickness, centering the pull rope basket, air flow to much or not enough. It is noted in the instructions that Perks is not responsible for recoil issues because of BRP poor design in which they already had issues. With that being said, I'm in talks with an investor that we will help with compensation in the near future.
3. Late models 2008 and later rotor thickness and weight. All three issues have resolved
AND FOR THOSE WHO ARE MY COMPETITORS !!!!!!!!!!!!!!!!!!!!
You noticed "NO REFERENCE TO BALANCING PROBLEMS"
The person who started this thread the Polaris 800 It was BALANCED
The Arctic Cat man of 2005 It was BALANCED
The person from Montana with the three motors - They were BALANCED
He called me after his first ride on his Dad's and told me that he couldn't keep the clutches from turning on the crank - Well guess what that means it now has much more torque. His Dad has called me also and I have tryed to give them the new rotors but they will not work with me. And then I see he has unbalanced the clutch. This is unbelieveable !!!!
The only problem or possible BALANCE problem there's something else causing vibration. Two other people in Montana had Wiseco pistons which have a different angle of unbalance, the clutch had rotated on the crank, not following assembly instructions, Roller bearings on the Arctic Cats.
My prices are half of the competitors and the customer paid for a BALANCE JOB - THAT HELPS WITH BELT BREAKAGE, CRANK BREAKAGE, BEARING FAILURE, AND VIBRATION ISSUES !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If the customer's belt breaks, crank breaks, or bearing fail they were already at the failure point. If it is a brand new sled (with little or no miles like my sled it will run for thousands of miles.)
EVERY SKI-DOO PRIMARY CLUTCH IS OUT OF BALANCE (2 PLANE) 5 GRAMS TO 40 GRAMS ON THE FRONT END AND 1 TO 5 GRAMS ON THE BACK END. THE NEW 2011 & 2012 POLARIS PROS ARE .5 GRAMS TO 3 GRAMS FRONT & BACK.
We just got done with a 2011 Polaris Pro (full engine balance) and went out and tested it. Top speed before was 86 or 87 mph. After balance at 300 feet to 500 feet (5 different times) 91 and hitting the REV LIMIT !!!
Because of the good balance job by the Polaris manufacture we will have a bolt on product "Eternal Engine Balance Kit" for the 800 Polaris Pros 2011 & 2012 (You can't believe how smooth).
With this new investor Perks will be purchasing a Track Dyno and let the customer film and witness the numbers before balance and then after and if there is no increases then the Balance is FREE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
NO ! not on my 2009 polaris 800 snowmobile (fact) which perks guaranteed me that it would with great results !!!
Perks (Joe) problem is that he does little or no " long term " testing on his own snowmobiles !!
He is using his customers snowmobile for R&D ( Research and development , experimenting on, or being perks so called guinea pigs ) with out the customers knowing about it , and it is costing perks customers a lot of money and time and damage to there snowmobiles ..
1-Perks is guaranteeing there balance kits works and with great results
2-no more belt breakage
3- more rpm
4- more horsepower
5-no more bearing failure
6-no more crank failure
7-motor will last 10,000 miles or more
8-perks (Joe) snowmobile is getting faster and faster in his garage
9-perks (Joe) snowmobile will never have bearing failure
10- little or no more vibration
11-ext , ext , ext, guarantee , guarantee , guarantee, ( in perks spin balance videos)
And then when you have a problems with perks balance kit , and it fails to do what perks is guaranteeing and causes damage , perks then tries to shifts the blame on to the manufacture of the snowmobile , Because perks thinks this is the best way to avoid explaining the problems with the balance kits failing and causing damage to the customers snowmobiles !!!
!!! Perks you say that your glad your balance kit is off the snowmobile motor !!!
How much longer do you think I should have left your (complete balance kit) on the snowmobile motor , until the motor shook and vibrated into pieces !!! Just because your perks complete balance kit is no longer on the motor does not release you from future damage your kit has done to the motor , Just ask A few mechanics , that know a lot about snowmobile motors to watch the video ..
Ask the mechanics if they would put in writing , how long they would guarantee the motor to last on the snowmobile now !! ask them to write a parts list off what that balance job could have done !!
Then tell the mechanics that is your work , and you personally installed the balance kit on the snowmobile , and you also guaranteed it would not cause any damage to the snowmobile !!
Perks is claiming new product for 2011 and 2012 polaris pro snowmobile , and promising great results just after 5 runs at 300 to 500 feet !!! This is perks problem , not enough proven testing on there balance kits , and Joe makes the statement ,and puts it in print !!!
ABOUT the voice mail , the reason Joe called and left a message is because , I called Joe and talked to him about the POOR results of his (complete balance kit) ,loosing 450 rpm ,no pulling power and parts breaking and that I was not happy !!! And then Joe called back later and left the voice mail ,in which Joe said he had A " idea " about the vibration ...
And perks !! There is some very smart people on SNOWEST that do know a lot about motors ,balancing and snowmobile !!! Who do you think your fooling being dishonest !!!
