It's kind of like when you read SLPs clutching instructions for the Performance edition kit. They say the stock 36 degree heilx is good but, the 42/36 (MULTI-ANGLE ONLY) is better.
It would be similar to say the stock orange spring is good but, the Fett Brother's Green/white is better. I say that because the Fett Brother's spring is the only one of three I have had a chance to test so far. The Skidoo purple/purple or the Starightline silver may be even better?
Also, did you send SLP your primary clutch to have them balance it, shim it and install your MTX weights? Once the weights are installed, make sure they swing freely. If they are pinched too tight with the rubber O rings, they won't move freely and your clutches will enagage with a BANG and you'll tend to dig big holes.
Then there's the tale of what primary spring works best..............................
