Have the PCV for a 2009 Dragon 163 c/w SLP single pipe. Machine runs assume without PCV connected. I run at 3000-6000' in the northwest part of BC. I originally wanted the PCV for piece of mind for the mid range lean issue and potential burn down. Not so sure now. With the PCV connected the engine consistently has a very noticeable mid range giggle over the 5500-6750 rpm range. I have tried two maps from Dyno Jim and the SLP map. Same story with all three. I do not have a Auto tune unit but did lean the SLP map down in the mid range and it helped a little. Ran this for half a day only. Diconeccted the PCV and engine ran great. Reason for leaning the SLP down was that it was the leanest of all three maps in the mid range to begin with and Dyno Jim had originally suggested to me to run the map with the leanest mix because my machine was running very well with NO mid range issues at all to begin with.Thought this was going to be a plug and run thing,I guess not???????? Really at a loss here.
