jeepin270,
gmustangt is correct with all of his facts. Thank you for your interim assistance providing information to a new Power Commander user.
Maps for any snowmobile PCV can be obtained from one of our great dealers. When they create a modification such as a pipe/intake/porting setup, they spend countless hours on the dyno and in the field developing a coherent map for the setup. These dealers provide fantastic customer support helping with PCV setup or mapping assistance.
Turbos may be another story since fewer dealers are utilizing the PCV for their applications - yet. This is changing as we become more and more noticed in the sled world....
Jim's map from Dynotech is made for a stock machine to improve the midrange on the CFI4's. Depending on your ECU flash, injector color, and sled modifications - his map may or may not be the ticket to clearing up the midrange. Advancing the map out to individual injector control creates a scenario that is not what Jim's map was built for. Therefore, there is no reason for the PCV to keep the prior map since it no longer applies -- though if you wish to run it as a base, copy Jim's map before advancing your device, then paste the values into the Fuel tables for all cylinders.
Yet - Since you've bolted a turbo onto the end of the exhaust which heavily restricts flow at low RPM/TP, you'll need to subtract a significant amount of fuel from the bottom end. For your CFI4, this would be the upper right corner of the Fuel table for Cylinder 1 and 2. These tables and range of RPM/TP's correspond to the Primary (part load) injectors that operate at low load conditions where many turbos stumble off the bottom end. I'd recommend a negative 10 in the 20 and 40%TP columns from 0-4500RPM. Then a negative 15 in the 60 and 80%TP columns from 0-5000RPM. And Finally, a negative 20 in the 100%TP column from 0-5500RPM.
The pressure tables will be the very Easy part for you. Since the PCV-PTI comes with dual TMAP sensors letting us compensate for all pressures, you'll have to input NO numbers into the pressure tables. The CFI4 engine is lucky enough to not require secondary injectors since it already has 4 of them - leaving plenty of duty cycle left over to increase boost without running them static. Even by Leaving zeroes in this table still means that once your sled develops any PSI of boost, the PCV will still add the proper amount of fuel to keep your engine at the AFR requested by the ECU.
Running a 1:1 FPR is a wise thing to do on any fuel injected turbo machine to keep things at "theoretical correctness". Great plan to leave that on your sled.
The datalogging capability resides within the LCD-200 accessory. This plugs into the external CAN port of the PCV providing the user with datalogging, real time gauges, map sending, and in-field fuel adjustments as well as other features. Datalogging is not possible with a laptop.
Hooking up your AEM AFR to your specific PCV enabling the wideband to read into the control center is not possible.
Once your feet are firmly planted on the ground, you'll be off to a well tuned turbo Polaris.
~T.J.
