AK,
PM me your e-mail and I'll fire you that map right now.
GKR
I'm on the original update map that came with the piston/head update. Mine was done in Dec. 09. PM me your e-mail sonday_2
Not specifically for high altitude no. Bring the map up on your screen in the PCV software and look at the notes at the bottom of the table. On SLP's for instance it recommends you turn on an accelerator function in the PCV for low altitudes. I would guess the DT maps are probably all good but do keep in mind some or all of these are for an SLP pipe too which I have. If you don't, read the notes and if its a map for an SLP piped sled you may want to see if you can find one for a stock pipe, they will be around or on DT's site.
If there are no notes, go to the top under the view menu and you can turn notes on.
Just some follow up on this thread. I rode last weekend and had further chance to test out things. At this stage I only connected my ethanol wires and continued with the SLP map. Definite difference from last ride so the overall 5% leaner condition with the wires plugged together was a big help. Sled ran amazing all day in all aspects. Midrange fat burble seems much less of an issue, top end was fantastic.
Unfortunately season is over for me now so I'll pick up on this again next fall. My next step is to try the DT Chad map which has a little less fuel again in the mid and see how it works.
Overall great season on the Dragon, sled absolutely rips, and in the words of my riding buddy on his M1 Cat, "that's the best running 800 I've ever seen"
Hope it sticks!![]()
no new maps for reflash 4/8/10
I have a DTR map for the 14 Jan 10 re-flash. Nothing for the Latest flash.
PM sent.
akrevrider
