Here's my summary on the PCV which I just installed and ran for one weekend so far.
First off, I'll qualify my set up. 09 Dragon, on original UPDATE flash (done Dec.09). Running SLP pipe/can/y-pipe, cold air intake, 19/42 gears, Carls helix, Ron's weights. Prior to PCV install I have been running with ethanol wires unplugged at all times and sled has run FANTASTIC.
Based on the above I was hesitant to buy PCV but opted to try it for any small potential gains but also the "safety" in the mid range.
I got the SLP map and two of the Dynotech Jim maps to compare. I opted for the SLP map. (by the way, SLP and Jim both recommended the original update flash as the best one to start from) The reason I chose the SLP map after viewing them in the PCV software was that the DTJ maps were rich in the mid by a huge amount, upwards of 20% as well as added fuel around or just off idle. The top end was similar although SLP was very slightly leaner. Based on how well mine ran without the PCV, I felt that much added fuel in the mid was way too much.
I also took the time to sync my TPS which was a good choice as the default was off. This is an easy procedure which requires you to install the PCV, connect your laptop with the PCV software running, and power up your ECU (which I did with a 12V battery) and in the software there is a simple step to set IDLE TPS voltage and WOT TPS voltage to sync the PCV and sled together.
Ran the sled at 3500-6500' on the weekend, above freezing temps, heavy, deep snow.
Sled ran excellent all day long. No major gains that I can brag about but it did run very clean on the top end. Did not see a clear gain in RPM as expected but the snow was wet and heavy which may have contributed. Mid was responsive and strong although it did sound slightly rich still but not enough to be an issue. Probably hurt mileage slightly but would be certainly safer from the mid range burn down perspective.
I would consider a couple changes to the map to take a slight amount of fuel out of the mid which I can easily do and save as my own custom map.
One question I have now is if I plug in the ethanol wires do I get a clean 5% leaner map all the way thru?? Can anyone confirm the specific effect of plugging the wires in? I have heard about "5% leaner" but would like a confirmation. This may be all the correction I need.
Overall, happy with my purchase and I look forward to further fine tweaks to get it right on the money. Very easy to use software and install.
Cheers.
