pcv, duel map?
i have the pcv and would like to know about how to add switch to run 2 maps. i tried jim's map and had a bit of stumble in mid-range so he sent another to try. currently i'm running slp map, but would like to have both in pcv to see which one i like better. i see where one wire goes into commander from switch i assume and guessing you hook a power wire into other side of switch. thanks
I have been wondering the same thing, sorry I dont have info for you.
How do you like the slp map? and at what elevation do you ride ?
where the screws are on the backside of the PC V the first two holes are for the switch wires and you set it up on the software one map with the switch off (normally open) and the other with the switch on (normally closed) it is all in the set up manual
thanks, for some reason i thought there was only one plug-in. now i see both. i have run the slp map for a couple rides and seems to run very well. but i want the switch so i can run jim's as well and compare on the snow.
What Polaris mapping are you running? I better go install mine.
It may be a bit of a pain to pack a laptop or notebook computer with you, but if you do, you can just select from any saved map and try it out. I have two maps from Jim at Dynotech on the laptop, and actually adjusted one of them a little bit on the hill, and saved it as a third. Now I can choose to load any one of them and go try. I want to thank Jim again, as the PCV and his help have given me my sled back.
