M
MTdream
Well, I am sure others are like me and been waiting for the day when you can set your sled to the level of insanity you want, and it always maps the fuel to that level for you...ragged edge or safe and secure...
Not just your daddies Fuel controller...and the closest thing to a Mass Air Flow Sensor we have ever seen in sledding...
PowerCommander V (replaces teh PCIII)
Here are specs...
And here is the REAL secret sauce...Set a AFR and it will manage fuel to that level...
Here is a pic of the map...
Have mine on order From Allen Ulmer (UlmerRacing.com) who is working out maps etc. for his boost kits....
cant say I can answer most or even a lot of questions but glad to try and maybe Allen will chime in and answer some...
for me this is a LONG time in the waiting!!!!
Here are specs...
Power Commander V Product Introduction
The New Power Commander V is loaded with tons of new features. It is compatible with 2009 and newer bike models. Below you will find some Power Commander V features. •Reduced size from PCIIIusb (less than half of the size of PCIII)
•USB powered from computer (9 volt adapter is no longer needed for programming)
•2 position map switching function built in (map switch not included)
•Gear input (allows for map adjustment based on gear and speed)
•Analog input (allows user to install any 0-5 volt sensor and build an adjustment table based on its input such as boost or temperature)
•With gear position input connected the PCV is capable of allowing each cylinder to be mapped individually and for each gear (for example: on a 4 cylinder bike with a six speed transmission there could be up to 24 separate fuel tables).
•Unit has a -100/+250% fuel change range (up from -100/+100%). This allows more adjustment range for 8 injector sportbikes
•10 throttle position columns (up from 9 on PCIIIusb)
•Enhanced “accel pump” utility (increased adjustment and sensitivity ranges)
Once installed, the Auto Tune kit monitors the fuel mixture (by installing the included Wide Band O2 sensor in the exhaust). It then sends this information to the Power Commander V and automatically corrects it while you ride. Each map that we offer has preset Air/Fuel ratio values included that we find to be the best overall settings. This lets you simply plug in the unit and let it do the work
For advanced users that would like to change the Air/Fuel ratios from our baseline they are fully adjustable. Each throttle opening/rpm combination is individually adjustable, so that you can have both fuel economy, during cruise, while maintaining peak output at larger throttle openings. For most models of bikes it is also possible to adjust the Air/Fuel ratios "per gear". This gives you total control of the fueling in every gear and throttle/rpm area if required.
