PC5 and auto tune
T
twincam88
just wondering if anyone is running the pc5 and auto tune? where did you mount the o2 sensor? how did it work? do you need a map or will the auto tune build one for me? any help is appericiated!!
You need a pretty strong base map to make it work right.
You mount the 02 sensor in the pipe, close to the silencer.
It works OK with a good base map, but you still have to fine tune it after the autotune makes its recommendations.
my dealer here has a good map he got from Ulmer last year so i going to try that one. how far from the muffler/slip joint would you mount it? doesnt the auto tune adjust the a/f ratio automaticly?
What turbo kit are you using?
If non turbo, you can mount the 02 about 3 inches toward the engine from the muffler joint area.
The autotune does not adjust AFR. You set up an AFR table and then the autotune makes recommendations to achieve that AFR. So if you put 13:1 in a cell and you are running 12:1, the autotune would say that you need 4 points of fuel taken out of that cell to get to the 13:1 you asked for. So if your value in that cell was 12, you would run 8 in there instead to get to that AFR.
Ulmers has some good maps and should be a great starting point.
im running n/a. so if the auto tune doesnt change it automatically i have to go in there and change it using my laptop? i was under the impression that it is a plug in and play and wouldnt have to do anything it would always be doing it for me. sounds like its not worth it. my dealer has a good map from ulmer he got last year maybe ill just run the pc5. thanks racinstation for this help i really appriciate it!!!
