First of all I had bought this system used and it came with the a Boondocker box and in the charge tube injector.
Since I did a IC set up and a fresh air intake and only use the stock 2 injectors so I could tie in with the PC 5 turbo box.
I will say that for me that is new to the turbo word this has been a hell of a ride and I have learned a ton along the way. I have had several big bores and always done my own tuning and project builds so I do have a medium level of mechanic knowledge.
The PC 5 and auto tune is a great system and it took some time to get it figured out, but I'm really close now.
1. tip would be to get the pc5 and auto tune on the sled.
2. when you start the sled unless you have somebodies real numbers it is alot easier to start with zeros across the board on everything including the auto tune or just leave the AT off until you get the numbers somewhat close.
3. with your laptop hooked up to start the sled or in the PC software make sure you turn on the trace feature and I liked to have the trace last 1.5 seconds so when you give the sled throttle you can watch it run through RPM/% of throttle so you know where your in need of adjustment
4. I used duct tape and taped my lap top to the sled between me and the handle bars so I could drive the sled around and see what it was doing for afr's and the feel of the sled and made adjustments accordingly slowly I might add +10 or -5 and such
5. spent a couple hours and started to get the lower portion under 50% tps to run decent.
6. just keep moving into the next range until it will go from 0%-50% throttle.
7. at this point you can activate the auto tune and plug in the Target AFR that you wish the auto tune to use example 100% 7500-85000 rpm I wanted to start with 12.3 90% used the same and then as I went diagonal back down the range I made it leaner to about 13.8 at 50% 6000 rpm.
8. I did use TPS auto instead of boost pressure.
9. for the start I did let the auto tune have a +- range of 20% ran the sled through them ranges slowly and maybe held it for a couple of seconds in each range.
10. stopped and clicked the get map function and looked at what the AT wanted to tune. If I liked it and most of the time I did I would accept that map. After lots of runs I started to only have +- 10%
11. now that the sled ran good enough to ride I stuffed the laptop in my back pack and stopped every 20 minutes of riding and did the get map and accept tune function if I liked it. sometimes it would through a big number in just one cell IE: 80% tps and at 7500 rpm it wouldnt align with the cell above or below it so I would just leave that number alone.
12. after 2 days of riding and checking it less and less I took the AT feature and just had it working at the 90 and 100% and above 7800 rpm range and left my 12.3 number in there. I did switch the +- to 5% though.
I'm sorry for the long winded explanation, but I wish when I started I could have had someone on here that had experience with this and had a write up.
I will thank TJ from powercommander for answering all my questions and I did talk to some of the guys from Speedwerx about tuning and that was a big help.
If you want fire away with questions.
after two winter of not being happy with my sled I finally have a ride able turbo that really runs well and I can't wait for next year.
