PARTS TURBO DRAGON PARTS
R
RidnHigh
NEW UPDATED LIST WITH NEW PRICES 4/29/2011
~Complete Part Out~
Will Update Every Day As to What Has Sold
No Money in Hand Or Check on the Way Means Parts Are Still For Sale
Pictures Available Upon Request
509-998-0888
Shanessi@Comcast.Net
or PM Me Here
COMPLETE 2009 Dragon 800 CFI Motor with New Top End 600 Miles Ago, 2100 Total Miles, Crank Run Out is In Spec, and 2009 Superseded ECU Map, Stock Gauge, and All Wiring, throttle boddies everything you need to run. $1,800.00 OBO
2010 Boondocker Pump Gas Turbo System with EBC, Includes Pipe, Clutching, Koso Fast Response Gauges, Boondocker Fuel Controller, and Oil Reservoir with Breather Cylinder – EBC and BD Box Just Reflashed and Gel Filled $2,300.00 SOLD
Stock Front Suspension, Right Side Perfect, Left Side Lower Arm Has Tweak, But I have 500 Miles on Tweak, NOT Cracked-Just Lil Bend $150.00
163 Tunnel and Bulkhead with Mountain Fit Hoods Running Boards Installed, Straight as An Arrow, Includes Taillight, These Boards Don’t Cut Out The Whole Board So if You Would Like to Use Snow Eliminators or Better Boards You Still Can By Just Unbolting the Hardware $850.00
Stock White Hood with Arctic FX Removable Wrap, No Cracks, and Mtn. Fit Windshield Vent, Comes With Windshield Hardware $250.00
Black Vented Mountain Fit Headlight Delete $40.00
Stock Side Panels With Removable Wrap on Them $140.00
Will Make Deal on Hood and Side Panel Combo to Match Wrap
2009 Seat with Black Seat Post $200.00
Fuel Tank with Fuel Pump and Wiring Harness $160.00
2009 Center Console and Plastic $80.00
Team Secondary Clutch $150.00
Mountain Fit TPO Black Hood, Fully Mountable to Hinge and Sled, Includes Four Piece White Hood Vent Kit, Gauge Vent, Stock Gauge Mount Bracket, White Vented Headlight Delete, Has Mtn Fit Air Shel Installed As Well So It Can Be used With Stock Air Intake, and Rubber Hood Strap Kit $280.00
2” Stock Polaris Riser Block $10.00
Magnesium Chaincase and Brake Setup with Jack Shaft and Brackets $120.00
Misc Parts Make Offer
Mud Flap, Stock Drivers, Rail Tips, Stock Air Box
Thanks in Advance, Tell All Your Buddies
RIDNHIGH
PICS NOW INCLUDED, GET SOME
For the stock front suspension. What is included? A-arms? Shocks?
I'll take it if so. Pics of damage?
