Parting out 2001 Summit 800 Highmark
I will have to look around in my garage but Im pretty sure I threw out the windshield long ago.
The track is a 151.
The skis are the 6.9 skis off of a Rev, they work great on the ZX chassis.
how much for the skid and track? what and what condition is the track? is the skid bent?
The track is the stock one with 2500 miles. There are some torn and missing lugs but it still works good, I will have to check when I get home to see how many are missing.
The skid is not bent, make me an offer.
Front end parts
I am in need of some front end parts. I need both the upper and lower control arms,the trailing arm,the front shocks,and the outer tie rod. Do you have these yet and how much do you think you would want for them? I also sent you a PM.
Thanks
Sold so far:
Crankcase (but not the crank)
Primary Clutch
DPM Tube and wiring
Y Pipe
Pipe
Reed Valves
Coolant Reservoir
Engine mount bolts (mount to bulkhead ones)
Right side trailing arm, shock, and control arms
Good cylinder and piston (Have other cylinder but it probably needs a hone, will sell very cheap)
Head
Bumper
Since it is a highmark do you still have the braided brake line for it, if so how much?
Still have:
Both trailing arms
Recoil starter (only used half a season)
Left side control arms and shock
MPEM unit
Tunnel and Bulkhead
Gas tank
Stock seat
Entire rear suspension and 151" track
Coil and spark plug wires
RAVE valves
Stock can
Probably some more stuff I'm not thinking of too.
Make me an offer, this stuff needs to leave my garage to make room for a new sled!
Located in Bozeman, MT
I'll take the coil and plug wires. The switches for the handwarmer and thumbwarmer also. also the y-pipe and reed cages if you still have them.
All thats left is the right side trailing arm $50 +shipping.
Everything else is gone!
Thanks for looking!
