Hello,
I’m currently running the PAR Ultimate Pro Combo(& clutch kit) & am interested in the opinions/feedback from those who are currently running or have first hand experience with this set up…………
Machine & current set up:
2011 Pro RMK 800(163”) – 1200 miles(450 miles with PAR Ultimate Pro Combo)
Riding 3000’ – 7000’ elevation
Rider weight w/gear – 270-275lbs
Modifications & maintenance
Wossner(RK Tek Direct Replacement Pistons) Compression 133/135 PSI w/13:1 PAR head
Yellow injector update (Polaris P/N 4013046-053) w/ecu re-flash
Fuel filter replacement (Polaris P/N 2521095) Pressure 59 – 60 PSI @ idle
Engine mount update kit (Polaris P/N 2204633)
Clutch maintenance(spider buttons to towers re-shimmed to .001”, belt clearance set to .020”, & re-balanced)
PAR Ultimate Pro Combo & clutch kit consisting of:
PAR 13:1 head
SLP pipe & silencer
Power Commander 5 w/SLP stage 3 map(P/N 70-228)
MDS weights(63 gram base weight with 5.7 grams on tip & 2.5 grams in middle)
Primary spring - 120/340(Polaris black/green)
Helix - 58-38-46-ER/58-40-46-ER(Team)
Secondary Spring – 160/240(Team black/purple)
The main issue that I’m having is occasional detonation on the trail while cruising between 6700 & 7200 RPM during light load operation(over ½ but less than ¾ throttle) – WOT operation is fine, no detonation…………Burning 91 octane fuel(as advertised at the pump)……….The 24 ohm ethanol resistor was installed with only a marginal reduction in detonation(if any)…………The pipe & silencer are tight & not rubbing on anything – The springs have been “siliconed” as well……… EV system is functioning properly…………….
After looking at the 70-228 fuel map, which has no fuel added in the above RPM & throttle position ranges, I’m assuming that the detonation may be mostly from a lean condition…………..In addition, despite idling smooth & having good throttle response, the engine seems to run rough as if it were loading up/running rich while riding slow in the trees(4500 – 5500 RPM @ 1/3 throttle or less) - Perhaps too much fuel is added in this range??? Just wondering if others are seeing the same results??? If so, what map changes have worked best for you, if you don’t mind sharing???
The next issue is clutching………. I have noticed that my engine speed has increased 200 – 300 RPM while cruising on the trail over the stock clutching set up which I assume is due to the shallower finish angle on the helix & stiffer secondary spring……..……Despite having gained 200 – 300 RPM on the trail, WOT pulls on hills in deep snow show top RPM to be down 150 – 200 from target(ideal being 8150???) depending on snow conditions with only about a 3 – 4 MPG gain in track speed over stock……….I’d planned on changing the loading of the weights to increase top RPM but considering the change of RPM on the trail & the minimal track speed increase over stock, I’m wondering if the stock helix & spring would be better with a more aggressive finish angle & less spring tension(56-42-36-ER & 155/222)……….
Any info. or suggestions would be greatly appreciated……………
Thanks in advance,
Glen
PAR 13:1 head
SLP pipe & silencer
Thanks in advance,
Glen
