Pace trailers?
check the frame for rust also look at all screws to make sure nopne are wallered out check for rotted wood in floor and doors check hinges for slop
I've had 3 Pace trailers. The only thing I would tell you to look for other that obvious corrosion, is to look at the ramp door hinges. If they are not cared for, they will stick and eventually break away from the frame and/or the door. They dont have grease zerks, but they use a rubber friction type grease nipple that is supposed to put grease into the hinge.
Other than that, and the fact that any steel trailer will rust, they are a great trailer. Decent customer service and as good of a product as anyone.
Good luck.
