P22 clutch removal
hamlin
I am away from my sled right now, but does a p22 have the same internal thread size/pitch as a p85? I have always used a bolt with a spacer or water to pull p85s, I’m wondering if I can use the same bolt with water. I bought the trs kit and a p85 to put on my boost. Thanks
same threads and taper...just a totally different puller. P85 much longer than P22 clutch puller...
I have a p85 puller that has half the length cut off it ( from being bent ). Used this cut puller for years on my p85 with water
If length is the only difference 22 vs 85.
Can I use my shortened 85 puller on my 22 with the water trick ?
