Ok so everyone says to shim spider for correct side clearance on your clutch/belt. I know about engagement with small vs. big clearance.
But what about the position of the weight?
If you bought a cover with a side-clearance adjustment you could get your tight fit without shimming the spider any different, and the weights position would be different for say 1:1 ratio vs. a re-shimmed clutch.
Any thoughts on what works better in the steep and deep??
RS
RS
