P-85 Puller?
lords88
New member
I need to make a custom puller for my yamaha with a P-85 primary on it. I was wondering what the size of the puller bolt is and the thread count?Thanks in advance.
if you can just get a regular bolt or take a regular P85 puller and cut it down just past the threads, you can use the hydrolic method by filling up the center of the clutch with water and then threading the puller into the clutch. You usually have to put some teflon around the threads of the puller to keep the water from seeping out, but when you thread in the puller it creates pressure that will pop a clutch off with ease and the puller wont even touch the crank snout! You cant compress liquids!!
