Expected to start shipping January 24, 2025***
-We're so confident in this product that we offer a 12-month warranty.**
Upgrade your Polaris today and experience the difference.
www.firenice.us
Ride safely,
The Fire N Ice team
- Polaris P-22 Ultimate Clutch Bolt - Engineered for Peak Performance
Elevate your Polaris Matryx 2022+ Boost or 9R with the ultimate P-22 clutch bolt.
Partnering with the industry-leading ARP Bolts, we've engineered a custom bolt that surpasses expectations. This isn't just a bolt; it's a performance upgrade, designed to maximize your snowmobile's performance potential.
Polaris has repeatedly recalled its product to address this issue, but the problem persists. We've taken the initiative to provide a permanent solution.
Key Benefits:- Unmatched Strength: Crafted from superior ARP2000® alloy steel, this bolt is 46% stronger than stock, ensuring optimal clamp load and preventing component separation under extreme conditions.
- Enhanced Durability: With a hardness level 32% higher than stock, this bolt is built to withstand the rigors of demanding riding.
- Precision Engineering: Made in the USA from premium SDF or CHQ grade material, exceeding aircraft-grade standards.
- Stress-Relieved Design: Shot peening removes stress risers, further enhancing the bolt's longevity and performance.
- Safety: This is not just a performance part. Losing a clutch bolt in the backcountry can leave you stranded. Having a bulletproof design allows you to make it home after every ride.
- Increased Clamp Load: Holds clutch components together in a solid, unmovable joint allowing for improved clutch performance.
Polaris P-22 Ultimate Clutch Bolt - Fire N Ice Performance
Polaris P-22 ultimate clutch bolt for your Polaris Matryx 2022+ boost and 9R to fix the known problem with these models. Backed with a 12 month warranty!
Ride safely,
The Fire N Ice team
