P
Pure Logic Tuning
NEW FOR 2013
POLARIS PRO 800
TURBO KITS
The OVS Polaris Pro turbo kit offers the hardcore power enthusiast the best components in the industry. This turbo kit offers the lightning fast spooling characteristics and the innovative designs that are demanded of today's turbocharged snowmobile enthusiasts. The turbo kit incorporates the use of a Comp oil-less turbo charger so there is no need for turbo oil, oil tank, oil pump or wiring for this turbocharger to provide countless hours of reliable arm stretching fun. OVS has once again has pushed the competition to the next level of simplicity and performance. OVS also includes all components in this kit so there are no extras for the customer to purchase. If you shop and compare no other competitor offers a kit so complete with the options that OVS *INCLUDES* in the Polaris Pro turbo kit. These options are oil-less turbo-$500.00 option, Tial stainless turbine housing-$700.00 option, OVS billet compressor wheel-$700.00 option and AEM 02 sensor kit-$289.00 option.
POLARIS PRO STAGE-1 TURBO KIT $4999.00 USD
This kit includes-
*Comp oil-less 28series turbocharger
*Billet compressor wheel
* Stainless steel Tial housing
* 38mm external Tial waste gate
*3" High Flow Muffler
*OVS Cold air intake
* 2.5" Charge tube
* OVS/Simmons o-ring billet air box
*Blow-off valve
* Boost gauge
*Fuel pressure gauge
*AEM 02 gauge
* Handle bar gauge mount system
*Pure Logic Fuel controller
*Billet throttle body boots
*OVS clutching components
*Turbo exhaust springs
*High temp silicone hoses
*All components to complete install
POLARIS PRO STAGE-2 TURBO KIT $5499.00 USD
This kit includes-
* 2.5" polished charge tube
*Blow-off valve
* Boost gauge
*AEM 02 gauge
*Pure Logic 4-injector fuel controller
*OVS pipe clamp system
*OVS reed cage extenders
*Auxiliary fuel injectors
*Billet auxiliary fuel rail
*Adjustable boost controller
POLARIS PRO STAGE-3 TURBO KIT $6499.00 USD
The Polaris Pro 800 stage-3 turbo kit is the real deal with a independent Air/Water intercooler system. This system keeps the charge temps ice cold because of the independent tunnel cooler and water pump used in the stage-3 kit. OVS after a day of riding and data logging showed a average charge temp of 69 degrees. OVS tested a intercooler system that relied upon the engine coolant and the existing tunnel cooler. The results of this day of riding and data logging was shocking. The best this system could cool the average charge temperature was 190 degrees and was totally inconsistent because of the the temperature of the engine was constantly fluctuating. The results of complete testing of both types of intercooler systems made the choice obvious to OVS which intercooler system to include in the Polaris Pro Stage-3 Turbo Kit.
This kit includes-
*Blow-off valve
* Boost gauge
*AEM 02 gauge
*Independent air/water intercooler
*Tunnel cooler
*Water pump
For more information contact
Travis at (801)940-7777
Garr at (801)791-0403
Shop (801)745-3833
www.ogdenvalleysports.com/tial_88.html
POLARIS PRO 800
TURBO KITS
This kit includes-
* 2.5" Charge tube
*Blow-off valve
* Boost gauge
*AEM 02 gauge
This kit includes-
*Blow-off valve
* Boost gauge
*AEM 02 gauge
This kit includes-
*Blow-off valve
* Boost gauge
*AEM 02 gauge
*Tunnel cooler
*Water pump
Shop (801)745-3833
