Ovs install?
ACTM7
Installing areo 66 on m8 useing ovs kit have not mounted air box but it looks like you have to remove alum. from the front of bulkhead or maybe install reeds on thottle bodys and air box then bolt reeds to engine? anybody install one of thes kits?
Clutch side top of bulkhead cut the curve out of the inside area behind the steering/suspension post. You the drop the airbox in from the top and the throttlebodies don't have to be removed.
hes got it and put some sort of lube on the air box we used white low temp lithium grease they are a ***** to get on sometimes
what i did to mine when i installed the cutler kit i had on my m7, looked like this after removing some of the bulkhead.turbo was removed from the sled prior to taking the picture.
i dont have an m8 here right now to see if they are any different, but it sure made getting the charge box in and out a whole lot easier on the m7.....mm
