Ovs 2009 turbo kits (automotive)
P
Pure Logic Tuning
OVS has the new automotive kit available for preseason orders. This turbo kit
has the cleanest fit and finish and performance in the industry. This kit has been tested for a full year and has flawless performance. This kit was ran at Jackson by Parker Brown and set a hill climb in 2008. The kit has new industry leading components for 2009 that makes this kit the easiest kit to install.
1. New design air box. This air box is o-ring fitted for perfect seal and no hoses or clamps on the throttle bodies. This air box also attaches to the engine with a single bolt design so this kit will never dislodge the throttle bodies under high boost pressures.
2. One piece charge tube with no welds. This charge tube is one piece with no welds so there is no possibility of leakage under high boost. The chage tube also is very short for quick spool time. The bling factor is great also.
3. The garrett turbo charger. The garrett turbo charger has the perfect combination of spool time and top end speed.
THE PICS OF THE KIT ON THE SLED WILL BE AVAILABLE ON THE WEBSITE JULY 8 AT www.ogdenvalleysports.com. THE PICS OF THE NEW AIR BOX DESIGN ARE ON THE WEBSITE UNDER (WHAT'S NEW) AT THIS TIME.
The turbo kit complete includes-
GARRETT TURBO
BLOWOF VALVE
CHARGE TUBE
AIR BOX
OIL PUMP
OIL CAN
ALL THE HOSE NEEDED
ALL THE CLAMPS NEEDED
ALL THE BOLTS NEEDED
PURE LOGIC CONTROL BOX
ALL WIRING
02 GAUGE
BOOST GAUGE
FUEL PRESSURE GAUGE
FUEL REGULATOR
ALL HOSE BARBS AND FUEL "T"
TURBO EXHAUST WITH MUFFLER
PRIMARY AND SECONDARY CLUTCHING
Is this a race fuel/pump fuel option?
Will it fit on an 08 POO 700?
Is this an installed price? If not, how much labor can you expect?
What about venting, is that another added cost for those that have not done the proper venting?
I'm very interested but the price is the highest I've seen yet.
You can use the stock pipe and head no problem, but I know they are working on further performance gains with different designs on both the head and pipe.
This kit is a race gas kit. Labor to do the install on this kit is $250.00. The side panel venting on the Dragon/RMK is included with the kit. OVS has a pump gas kit it's cost is $3995.00 this kit is on the website. The race gas kit has alot of components The pump gas kit does not come with
1. BLOW OFF VALVE
2. AEM 02 GAUGE
3.PRIMARY CLUTCH SPRING
4.SECONDARY CLUTCH SPRING
5.CLUTCH WEIGHTS
6.TEAM HELIX
7.BOOST GAUGE
8.BOOST CONTROLLER
9.ONE PIECE BOOST TUBE
10-SIMMONS AIR BOX (O-RING FITTED)
11-OIL PUMP
12-OIL TANK
THE LIST IS LONG.
THE PARTS IN THIS KIT ARE NOT CHEAP OR LOW COST BUT PERFORMANCE STANDS FOR ITSELF. WE COULD USE CHEAPER COMPONENTS LIKE PLASTIC BLOW OFF VALVES, HOSES AND CLAMPS ON THE AIR BOX, WELDED CHARGE TUBES BUT WE WANT A HIGHER QUALITY BETTER RUNNING AND BETTER LOOKING PRODUCT. THANKS PL
There is a mod option available for the turbo's it has a y-pipe a custom pipe and the head. This option will be priced and put on the website the end of July we are waiting on the vendors for the final pricing. This mod has proven to make alot more midrange and top end for those who want the fastest turbo package.
