You will use about 17% more LP than gasoline.... so you better have a large enough tank to make 'er home.
12 gallons will get you at least 70 miles of hard deep snow riding. and believe it or not simmons can make a small transfer "jerry tank"
That would be my concern, would be nice if the tank were disconnectable so you could buy extra tanks and have them filled anywhere, or if there was a fitting/hose so you could transfer a small coleman lantern cylinder or 5 lb bottle in a pinch...I am curious.
This idea sounds awesome but the logistics of the fuel is a head scratcher. It would be a pain to have to fill from the trailer, especially if the tank is at 10 degrees from overnight chill and the sled tank is warmed up from a day of riding and sitting empty out in the sun. You would need a trailer tank heater or a propane pump and some time to kill. How do you check the fuel level while riding? What is the tank made out of? How much boost would it run at sea level, how would it adjust?
The propane sleds have shown after a month of riding that the fuel mileage is about the same as gas not 17% less if anything 17% better. You can get buddy tanks to increase the amount of propane you can pack. The stock seat can not be used it does not have enough room for the tank. The seat will be as good as the stock seat because we have liked the seat quite well also.
Liquefied Petroleum Gas (C3H8) contains roughly 17% less thermal energy by volume when compared with gasoline (C8H18)
I don't care how you burn it or what you run it in, you won't go as far......
Don't get me wrong; I am a huge proponent of anything propane powered, but the end user should be properly informed.
yammy what part of tonys post was defensive?? have a beer and read it again, everything was a question, possibly trying to understand 2 strokes and propane.
now that it burns 17% more fuel does it produce 17% more power? The last time I was around a propane vehicle it did not produce as much power as gas, does that change with boost and 2 stroke??
