Overhead sled storage project completed
Blk88GT
Westbound and down
I started
Section 1:
Section 2:
Section 3:
Winch:
Top view before old tracks screwed down:
Today:
very cool, i seem to be trippin all over mine all summer long too, and my second garage is 30x34. lol good job ps that car underneath isnt real expensive is it?? just kiddin looks plenty strong.
Storage
SWEET,nice job.don"t have to worry about mine.STILL RIDDING IN MONTANA,lots of snow up high...
Scott, I've seen yours and that's what gave me the idea. Thing is, the car is pretty hard to steer with street slicks, a spool and manual steering, so posts were not an option.
I like your system, nice to get them up and out of the way for the summer.
Here are some pics of how I do mine, but its nice when the boss has all the equipment.
The entire thing is 2x4 construction.
I built it in 3 sections, mainly because I'm a fan of desinging as I build (lol)
First: 10' x 4'
Second: 7 x 4'
Third: 12 x 3' 46 1/2" (I had to set the ramp section off the wall by 1.5" to get around my air and telecommunications lines)
Total length is 29ft.
Everything is sheeted in 7/16 OSB. I primed and painted everything before cutting which took FOR FRIGGEN EVER. I used joist hangers, corner braces etc. I used 3 - 6" strap hinges for the main pivot point that I lagged into beefed up sections so as to not pull them out.
Gussets are 5" in length and cut on 45s. I used 1/2" rod in 6ft lengths from Home Depot. I made the brackets for the roof and rails myself (first time welding since high school!)
There is a header for the weight to sit on that's been lagged into the wall, and the top frame sections are screwed in. The gusset header on the wall is 2x6 to distribute the weight between studs.
I used 3 tracks to put down for traction. The last one hangs off the end so I get some traction when the sled is on the concrete. I can barely get the shorties to fit between the back wall and the ramp, so the long one should be fun to watch ;)
If anyone has questions, let me know. It was a fun project but I'm glad it's done.
Forgot to mention, I'm into the entire thing for under $500 since I used some primer I bought 6 years ago (LOL) after chiseling off the top dried up layer. :)
So the part that hinges down...I see that when it is up you have the kickers underneath. You have to remove those each time to lower the ramp I assume?? and if so do you think the ready rod would be sufficient on that section by itself since it is the movable piece??
