Other brand of can on SLP pipe
D
Has anyone tried a different can other than SLPs on a 06 900 RMK with their pipe. Seems to me there is some room for a bit more weight loss plus it rubs on the chaincase bolts. Even though I am an old guy a little more exhaust note wouldn't hurt either.
K
Kevco
1,719
334
83
61
Sandy Ut.
Dually Im running a High Flow HPS can on my 07 600 RMK with my SLP pipe. I had to jet around the can but it is one of my secrets that makes my 600 bad a$$;)
P
polhiker
Nov 2, 2002
588
37
Chinook,montana
I got rid of the slp can and went with a CPI sounds great,better throttel responce and i lost another 2 to 2.5 lbs.and about 199.00 dollars.I even put it on my slp pipe not a great fit but dosen't leak.
SAWYER
6,096
296
83
42
Kingston Idaho
I had a slp pipe and cpi can on my old 900. Here's a pic
Don't know if hps makes one for the 900 but that would be my choice, they have high quality stuff. Here's one on my dragon with a slp pipe
D
Thanks for the pics. That's some serious plumbing on the CPI can for your 900. I like the looks of the HPS can on the Dragon. Clean installation and looks like good quality. I tried a search for HPS and no luck. Anyone know a dealer or how to get some info from them?
D
deepdiver
936
316
Marysville, WA
Check the Mod Stock magazine...pretty sure they had an ad in it. At work now but will check later at home if I can find where the wife hid it at!
D
dmj1
303
94
I bought a jaws can make your self kit, made the exhaust exit out the a arm well
so there will be no bog in the deep when leened over to right. 06 slp muffler was 13.5lbs
and the jaws can was 3.25 lbs.was definitaly louder and seemed to pull alittle harder.
also gets the heat away from chain case.
markoo
183
Southern Alberta
mbrp
I use a MBRP can on my 05 900. It fits perfectly with the stock pipe or with the slp pipe. It's a lot smaller and lighter than the slp can. It makes a bit more noise but works very well. I found the slp can, because it is so big it heats up the chain case and warps it.
