Nothing wrong with the clearance specs in the service manual - they are pretty much "typical" for an 800 twin motor. Some commenters on these forums have claimed their BRAND NEW pistons have been way over the specs for clearance and supposedly, Polaris has looked the other way. However, I can neither confirm nor deny the accuracy of those comments. My own experience says that if the factory pistons have the correct clearance, you will likely have a motor that stays in one piece. If the pistons are already out of spec, then you likely have a ticking time-bomb. However, no guarantee that the "FIX" will help either. There have been failures reported with those pistons too. Bottom line is that whatever pistons you choose, they must be fit correctly to the cylinders. If they aren't, they won't hold up like they should. Incidently, there are also claims made by persons on these forums that a couple well-known aftermarket shops have seen good success with replating the cylinders to restore correct piston clearances, rather than resorting to some "special" piston. Just something to think about...
