P
powerstroke 350700
Any buddy on here ever try any other products for belt life an engine stability?
Does it come with the tool? I sure hope so.
Bendy, it doesn't come with the cam. I wasn't aware Gene was brining any in, as I ordered mine direct from OSP - should have it by the weekend. Jim @ OSP suggested I order two eccentrics, as the mag mount can also be corrected if need be.
Joe, heat the chain case around the bearing until the residual oil starts to smoke - the bearing will pop out with the use of a pick, or you can strike it from the inside out with a kingpin from an old ford (still have to use heat). I never liked the idea of driving out a press fit bearing - I feel that you may damage the case doing so.You are correct Karl-I have the other for the mag side and inital measurments I will probally end up needing it.. Got the JS out finally but buggered up the threads on the bearing on the chain case upper bearing where the lock ring goes...I checked the service manual today and nothing was noted about removing or caution on the knock sensor.....
What kind of tool can I use to hammer out the bearing on the chain case instead of pulling it.. OSP web is using a old JS but unfortinally I am reusing me old one..
S/C
What keeps the concentric from turning in the hole that you drill?
