? on egt/contoller
I put a diamond intake and a SLP y pipe,pipe,can on a 07 M8. I was instructed that if my intake hole design was done so that I was pulling more warm air, I wouldn't need to make any adjustments to injectors(wouldn't need a controller box) I am super lean, super. do I have to put on a box, any advice??
I think you are money ahead with a control box. A top end will cost roughly twice what a control box would run. They are not hard to adjust\use. Probably will make more power with one once you get your numbers dialed in.
I ride out of Anchorage, 500-4100ish. Pulled plugs twice, once with new plugs. White as the snow. Lookin for advice.
I just put this setup on my sled this year also, so I too am wondering what others have their boondockers set at. I think on my boondocker I'm just going to richen it way up then, decrease the fuel based on plugs, egt, piston wash.:confused:
I would run a fuel box before any other mod most stock sleds run fat so you can do one thing air, exhaust but any combo will make it run lean.
I have a similiar set up and my sled needs fuel on the top 7800-8100. With the intake you may need more. You should test with some carbon build on plugs and test at different RPMs.
Jason
With A BDX intake and SLP Pipe Kit this is what I ran for fuel settings in yellowstone this year. Mine seem to run real well with this setup.
3000 -4 -4 -4
5000 0 0 0
6700 0 0 0
7800 4 4 4
8100 4 4 4
