Oil Tank Leak
K
ktm131rob
Morning,
My oil tank is leaking on my 17, what are the fixes other are using. I roll the sled a lot when I get it stuck and it made quite a mess over the weekend. I know others have had this problem but the search feature on this form really leaves a lot to be desired and I can never seem to find the simple stuff. What are you guys doing to fix this?
Thanks.
Where is it leaking???? Replace oil tank?
Sent from my SM-A530W using Tapatalk
easy to get the oil cap on cross threaded and it will leak then wnen rolled over, been there and done that! I have replaced my caps with Doo caps and it is still easy to cross thread them after filling with oil.
gtwitch in wyoming
gtwitch in wyoming
I have heard of that fix, didnt know if it worked or not. I dont believe that its cross threaded, I have looked at both the tank and the cap and the threads looked crisp.... I have cleaned the mess that it made now.. so I am going to order a ring and give that a shot
oil leak
Honestly..do both. I had the same problem, and installed the neck sleeve and a doo cap. The sleeve does an excellent job of not allowing the threads to deform. The doo cap is easier to get take on and off straight, and has a bettering venting system in it to prevent tank vacuum.
Sleeve: $15 cdn
Cap: $12 cdn
yeah, pretty easy to even just overtighten the cap and cause the tank to deform o nthe flats between threads. makes a pretty dumb mess.
I found just being more diligent about not cranking the thing down solved it for me.
