Like the title says my 2019 alpha is having trouble with the oil tank draining over periods of storage. Seems like the oil is in the crankcase causing a hydro lock condition currently. Last time it happened I was able to get the sled started (smoked and fat till it cleaned out)
Little more about the sled:
I have a MVM belt drive with plastic tank. Silber turbo with cycles and sleds clutching, boost T and BOV. runs very well except this issue. Just a little over 1000 miles.
No local cat dealer, few that I've talked with haven't given much direction
Is there a check valve assembly in the oil pump that could've failed causing this issue?
Seals in the water pump oil bath bad causing this?
Thanks in advance and feel free to correct any assumption I made right or wrong!
