does anyone have an oil pump spring? or does anyone know where to get the spring without buying a new oil pump? my pump is fine but the spring is toast. Thanks guys
After checking both the factory Polaris Microfiche and the Babbits one as well, neither of them list the spring individually, just the pump assembly and many other parts on the cross shaft. Have you tried asking your dealer to see if they can get you the spring individually?
I wonder if anyone else has had this specific need and figured out a distributor.
Maybe take the spring out and try to match it up with something a hardware store or fastenal or something....just make sure the spring load is were it should be at you dont want the pump to be stuck open or especially closed!!
That kind of sucks. I ran into this on an older poo with a broken loop (where it attaches to the arm/lever) and was able to fab the original just bending a new loop (very, very carefully). I'm sure someone will have an idea, I just can't seem to come up with one right now.
ya, i checked pure polaris and babbitts too, im not buying a new pump for a cheap azz spring, my local hardware store didnt have anything but they have a very limited selection. not even mountainhorse had anything so its a tricky situation
If you are having a problem with it not returning get yourself a exhaust spring and put on the cable. I had my second 900rmk sticking all the time so i put that on there and the fixed the problem
