oil pump location
The notorious oil cable is beneath the throttle bodies, and is a real PIA to change IMO... you can put a pen light down there and check to see if it's broke, it breaks at the tip where it attaches to the pulley on the throttle body... if that makes any sense... it'll be pretty evident if it's broke.... just replaced mine $26 for an OEM one at the dealer, which is more than likely stocked.
better yet, pull the throttle bodies, and replace both the stock throttle and oiler cable with the FBF or motionpro
never have to worry about that cheap little bugger breaking again
Do you have a picture of the motion pro one? I'd like to see what they've done different over the stock one.
