The cases have to be drilled on the pto side to properly lubricate the bearings. There is a spot in the casting already there just is not drilled, it also has to be drilled at the correct angle to get to the outer bearing.
The case mod isn't noting to lose sleep over. You can use a small ball burr and just grind a canal for the oil to get to the outer bearing. I hooked up hoses from both bearings tee'd them in the middle and ran the hose up top with a small cap so that I can still inject oil with a syringe after everyride.
