oil pool
T
TBSK
New member
Tried search to no avail, 09 Nytro MTX MCXpress have bad oil burning smell and smoke coming from exhaust? Turbo has small pool of oil sitting at bottom of inlet? Starts fine idels fine but when get the rpm up its a smoke show.
Check that the return pump is working. The mechanical pump on the side of the motor has a little pin in it that sometimes gets fubar'd.
May be as simple as this. Do you have a filter on the breather of the oil tank? Get rid of it now! Had mine do that with the catch system on the mcx you don't need it. The filter ices up inside from moisture from engine and pressures up system. Ty yamaha has been warning about this for a while, have had no problems since.
