oil line wearing on bulkhead
D
doobie
check your oil line. Mine seems to of wore thru the lume wrap already. Right were it come's off the oil pump and makes it's first bend, it rubs on the bulkhead. Could wear right thru if not adressed. simple fix, just zip tie it up top to give it that 1/2'' gap from the bulkhead.
Thanks for the heads up, checked mine, the loom was worn thru and wearing on the line, thanks again.
awesome heads up, these are the little posts that will keep you riding, thanks for the info!!!
IT'S TRUE
I all way's try to take most of the info on here with a grain of salt, untill I see it for my self, THIS IS FOR REAL, two of us checked today and both had started to cut thru, a simple fix just pull the line up and zip tie.
Thank's doobie
oil line
yes check your oil lines your dealer got a memo on them possibly having a kink in the line and it says not to pull up on the line also
I dont mean to hijack a thread but if you look at my thread i posted called Handle Wires / Oil Line Bulkhead / Oil Line Air Bubble i posted pictures the are a little small but you can see what to look for
