oil injection delete
If you haven't had your cases drilled out on the PTO side don't try it. You will loose the PTO bearings! I do the delete on all my sleds. One less thing to worry about going out and taking out a motor.
Yes, I deleted mine. I have an 02 700 and my cases came drilled from the factory. The 800s were not drilled. I would pull your head just to be sure.
I have 2 that Indy Dan has done for me. A 3rd will be done this summer.I lost a crank bearing to a pump that died. I said that is not going to happen again. You will love the room and ease of getting at stuff. Plus if you forget to put cap on oil tank after filling it like I did and then roll your sled down a hill with it landing upside down you will not have the mess this dumb *** had that day. I had lots of time to clean as I pulled my hamstring trying to grab sled to keep it from rolling down the hill.It was my first ride of season about 20 min into first ride.It took many rolls of paper to get it clean ! Just one more reason to get rid of tank !
Not sure you would see it by pulling the head but the head and pto cylinder you would
