Oil in air box
Ok i have an 07 m1000
it has speedwerx porting speedwerx pipe y-pipe and can timing key bd box slp intake and speedwerx head mod 14:1
well we took sled out last monday for our first road ride and when i got home i saw a small spot under the sled pulled the air box and it was wet in it and running down the skid plate and on the floor
i think it might just be way to rich my o2 gauge was not here yet so i dont know if it was or not and it was just a put down the road cause we had snow
also what would be good o2 numbers rich and lean
any help out there would be great thanx
o 2 guage
my o2 on my sled runs 12.3 on hard pull the numbers should be about same as egt you can call me if you want I work with Tom:D
Mine leaked last summer on the garage floor. They're @25 CDN each, there's three of them, and a real "pita" to get at, so I was going to wait until the leak got worse to change them. But I haven't seen a stray drop of oil since the first ride last winter. I like it when things fix themselves!!
Mine did this for a while as well. And as stated above, it eventually fixed itself.
The only problem with it was that you had to clean it up. I dont think you need to worry about your sled losing any performance, mine didnt.
